Hello I am a beginner student from Europe.
I would like to create a force regulation in LabView. There is a hydraulic cylinder with a load cell in the end of the rod.
I would like to create a simple PID regulation in LabView, I mean I type the force value in LabView, for example: 10kN and I load up the program to the NI9237 CompactRIO. Afterthat somehow, the analog output signal from crio go to the proportional hydraulic pressure relief. The cylinder create the force, the load cell measure it and send the analog output signal back to the crio. I hope you can understand me.
The load cell can receive tension signal
I need also a pressure relief what can receive tension signal
My question, is it possible ,what i would like to do? I do not understand, how can become the force signal to -10 - +10 V signal?
Thanks a lot!
