08-05-2015 08:47 PM
Hi i am new to OOP in labview.
How to use (ACCESS) same Object in multiple VI fiels in labview.
in c# if we use same name space , then we can acces the object .
i dont know how to use it in labview.
and also i need to know , how to use oop in large applications
08-05-2015 09:58 PM
08-06-2015 02:19 AM
hI Mike,
THANKS FOR YOUR RESPOMSE ,
I AM NEW TO LABVIEW OOP CONCEPT,
1.I HAVE ONE COM port Reading Class ,
2. from that class i am creating 2 objects (COM 1 , COM2) . in main VI ,.
How to Access that objects COM1 AND COM2 in sub vi files ?
08-06-2015 06:53 AM
You could just pass the objects into the subVIs via the connector pane and wires, just like any other data.
08-06-2015 09:44 AM
08-11-2015 07:06 AM
Thanks for the answer ,
Please give some Eample file ..
like OOP
Main vi creates the objects,
and subvi calling the same object and modifying .
I mean OOP + MAIN VI + SUBVI
08-11-2015 02:11 PM
08-11-2015 02:38 PM
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-11-2015 03:48 PM
Mike thanks for the reply,,
James.Morris thanks for the example.
after seeing example ,
i have another question.
whats the difference betweent LVOOP AND ACTOR FRAMEWORK.?
08-11-2015 03:58 PM
Oh boy...
Actor Framework uses LVOOP, they are not two different things, just one inside the other.
You need to do some of your own research to get your head around it.
To be honest, it sounds like you are new to LabVIEW, so maybe you should start off with basic LabVIEW programming practices before moving up to LVOOP and Actor Framework.
Cheers
