How to use repeated values in a ring text control? There are another similar control?
Accepted by topic author Chuckero
@Chuckero wrote:
The benefits of a ring is to group constants of same family, like, parameters of instrument, parameters of process, general parameters, etc.
And having a global variable file for each group will accomplish the same thing.  Plug each parameter will be able to be its own data type.
GCentral
Message 11 of 15
(960 Views)
I used a cluster of locals/globals for each group. That also permitted different data types.
Message 12 of 15
(952 Views)
Hi
There are an auto-update control? How about type defs?
Message 13 of 15
(943 Views)
It isn't really updating a ring control.  A global variable node is linked to a specific global variable file.  So if you add an item to that file, then everywhere you have a global linked to that file can use that value.
GCentral
Message 14 of 15
(938 Views)
I did a test right now, and using global variable files, one for each family of variable,  really meets my needs!
Thanks again!
Message 15 of 15
(924 Views)
