How to use different font styles in the same boolean text?
Hi all,
As reported here http://digital.ni.com/public.nsf/allkb/6BD344ACA4DEE20A8625692700737E16, it is possible to change font color, size or other font properties of a subtext in a string indicator. This can be applied to a caption too.
I'd like to apply this properties to a boolean text but it does not work. The boolean control has the Text.selectionStart and End property node but it does not appear to function.
Can you help me?
Thanks all
(2,985 Views)
This is a bug in the development environment (I think it showed up around LV8).
There's a workaround, but it seems to work intermittently: Place some floating text on your front panel, then edit it's font styles.  Select and copy the floating text.  Select the boolean text (double click on it).  Paste.
(2,970 Views)
With this workaround it works. Thanks
So, due to this bug, there is no way to do it programmatically. Right? 😞
Andrea
(2,962 Views)
I haven't been able to find a way to do it programatically.
(2,934 Views)
Apparently this is still an issue with LabVIEW 2018 and 2019.
(2,005 Views)
