01-30-2007 07:23 PM
01-30-2007 11:42 PM
01-31-2007 08:10 AM - edited 01-31-2007 08:10 AM
Message Edited by romulus on 01-31-2007 08:10 AM
01-31-2007 06:03 PM
01-31-2007 06:16 PM
02-01-2007 10:02 AM
@Jhoskins wrote:
This is done quite a bit actually. But my question is why not just package everything in one place with the LV Installer, run time and all. if you need to upgrade you SW then the run time engine will only be installed once. Or you could just make the run time engine a requirement and have them download it free from NI. This way you installer and EXE are small. I would hate to see how you would handle Daqmx calls with this type of framework and installation.
02-01-2007 10:12 AM
@romulus wrote:
2) Our software is mostly used in factories and a lot of times in China on a production line where access to the net is out of question.
But you're saying they need to download your installer, so at least at some point they should have access to the net, where they can download the RTE.
My suggestion to you - see if you can say no. Tell whoever's in charge that this sort of thing will not get any support from NI and that it is quite likely to break at some point. Instead, just try to come up with an easy way of getting the clients to download the RTE installer and install it.
02-08-2007 03:11 PM
