05-23-2008 03:10 PM
Solved! Go to Solution.
05-27-2008 06:43 PM
09-04-2015 12:19 PM
Primera actually has a SDK called PTBurn that allows you to do automation of their DVD duplicators.
Not exactly a drop into LabVIEW, but it's not too difficult to write some LV code to interface with their API.
09-04-2015 12:33 PM
Maybe they didn't 7 years ago...
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-04-2015 12:59 PM
Don't be so quick to judge.
PTBurn 2.5 came out in January of 2005, and many upgrades since then (and documentation suggests there were versions before 2.5 with reduced feature sets) .
I had the same problem as the OP, and found this post and it had no resolution, and didn't have any answers. Did a bunch of my own research and found the answer and wanted the information I found to be there so someone in my same situation searching the forums would have something to work from.
Yes it's an old post, but I don't know of a better way to document the information/answers (let me know if there is one).
