11-04-2011 06:08 AM - edited 11-04-2011 06:09 AM
Hi I am trying to use Generate Synchronization Parameters.vi to sync the recovered stream after demodulation and my input stream to modualtion block but I don't know how to work with this block to sync input stream with output stream. Also would you please let me know what are the ways to sync input bits and demodulation bit stream.I really appreciated your help
11-08-2011 03:55 AM
Hi en99,
In order to use "MT Generate Synchronization Parameters.vi" you must wire in the following on your block diagram:
What I have done is taken your 11.vi that you uploaded in your previous post and altered it to contain the sync vi. I have saved it as a 2010 version.
I hope this information helps!
Kind Regards,
03-24-2015 12:37 AM
Sir,
we are using output of mt generate bits block as an input to generate synchronization parameters block. But after adding sync bits the message stream is altered and we are getting a very high ber due to that.Kindly help in this regard.
03-25-2015 02:23 AM
where to find generate system parameters in labview??
how to start ask modulation in labview??
