How to use Demux in LabVIEW?
Could someone help me on how to divide/split signals in a bus to several outputs? I converting Demux from Matlab but having difficulties to use it in LabVIEW. Perhaps someone knows how to use it in LabVIEW or any other method that could perform the same thing as Demux.
Example, I had 10 signals in a bus and I wanted to split it to 5 different outputs where the first output contained 4 signals, 2nd outputs contained 3 signals and the rest contained 1 signals.
The signals could be anything, constant or any waveform signal.
(6,410 Views)
Accepted by topic author tebu
Search for Unbundle in Labview, it will solve ur problem................Smiley Wink
(6,384 Views)
Great. Thanks!
(6,334 Views)
