I recently upgraded from LabVIEW 6.0.2 to LabVIEW 7.1. I want to install the version of Ni-DAQ that came with LabVIEW 7.1. When I run the installation CD, it tells me that it can't install Ni-DAQ 7.2 because Ni-DAQ 6.8 is already installed, and that I should go to add/remove programs and uninstall Ni-DAQ 6.8. Ni-DAQ 6.8 in not listed in add/remove programs, so how do I uninstall it?
If you go to the Add/Remove programs, select National Instruments Software. This will bring up an installer window where you can choose which particular piece of software you want to remove. Good luck.
If I go to "National Instruments software" there are only three items listed - NI LabVIEW 7.1, NI Application builder 7.1, and NI Runtime engine 7.1.
There is a "LabVIEW 6.0" item in add/remove programs. If I click on the "Change" button, a message pops up saying "Error applying transforms. Verify that the specified transform paths are valid".
I've no idea what this means but it looks like I can't uninstall Ni-DAQ 6.8 from here either.
