NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
lshi
How to trigger user events inside Action Engine (or FGV) between multiple VIs?
[ Edited ]
I tried to use the AE to trigger user events in two VIs, but not successful. Only one of them can trigger the other depending on which starts first. What's the best way to to make a two-way communication (trigger)?
Active Participant
ThiCop
Re: How to trigger user events inside Action Engine (or FGV) between multiple VIs?
Hello Ishi,
Can you give some extra information about the actual application?
This would allow me to have a better insight into the issue your running into and the possible solutions.
Kind Regards,
Thierry C - Platinum Applications Engineer - NI Belgium
CLD
If someone helped you, let them know. Mark as solved and/or give a kudo. :smileywink:
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
