I'm using 7830R to generate pulse signals from multiple DIOs. In the FPGA vi, I added a menu ring which has two states, default is to run a pulse generation code in a for loop and stopped after the certain number of signals have been generated; while the 1 state is to run this pulse generation code in a while loop continously until I hit the stop buttion. Running the FPGA vi itself is OK as I expected.
The problem is how to put this menu ring selection in the host vi, so that whatever I choose from the front panel@ host vi can be transferred to the FPGA vi and do the job?
I tried to use the same menu ring in host vi, and add this "acquistion mode" element in the read/write control where I also input the pulse width, duty cycle etc in the host Vi. However, by doing this, I was only be able to get the default fixed view mode work, when I chose "continous", it only give me one pulse.
Searched around but found no answer, so I have to ask here. Please excuse me for this newbie question. Thanks.
