06-27-2012 05:06 AM
I am analyzing data from PXI-5600 through RFSA. I take the signal and show the power spectrum on a graph (frequency vs. power).
But i want to find specific points and get their frequency.
How do i get an array from the indata?
Solved! Go to Solution.
06-27-2012 08:41 AM
What color is the graph terminal on the block diagram?
Brown = Waveform Data Type - Use "Get Waveform Components" to get the "Y" component
Pink = Cluster - Use the unbundle to get the y info
or
Pink = Array of clusters (xy pairs) - Use a for loop to process the array, in the for loop use the unbundle to get the 2nd element (y value)
If none of the above helps, please post your code.
Charles
06-27-2012 09:12 AM
Oh my god, i didn't realize it was a cluster with values and one array!
Golden response, thank you so much!
