How to subtract a current value from loop iteration to value from previous loop iteration
I have a series of value getting from an experiment. It is located in the white loop section.
For example: 1   ;   3   ;  6;    9. (the last value is 9)
After running an analysis, the value (put in the loop) update to 1; 3; 6;9; 15 (the update value is 15)
Then for other run, the value (put in the loop) update to 1; 3; 6;9; 15; 25 (the update value is 25)
 I want to do a subtraction between 2 last value from the loop iteration. for this case 15- 9 = 6 and then 25 -15 = 10.
Could you please tell me the way to solve this problem?
(4,689 Views)
Open LabVIEW, go to Help, LabVIEW Help, click the Index Tab, type "Shift Registers", and read the Help Text.  Then write a little VI and try it out.
If this is brand new to you, for goodness sake, find some basic LabVIEW Tutorial Material and spend the time!
(4,685 Views)
 SR would be a start Smiley Wink
(4,654 Views)
For a change in scenery, you could also use a feedback node. 😄
(4,628 Views)
Status report? Success rate? Solar radiation? Senate resolution? Service request? Special relativity? ...
(4,627 Views)
Accepted by topic author achimost
Hi Achimost, this is Chris with National Instruments Applications Engineering. I know it has already been mentioned, but I wanted to provide some resources with basic information on Shift Registers. These are how we pass data between different loop iterations in LabVIEW. I would encourage looking into Stacked Shift Registers in the first link.
Passing Data Between Loop Iterations in LabVIEW
http://www.ni.com/getting-started/labview-basics/shift-registers
Shift Registers: Passing Values between Loop Iterations
http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/shift_registers_concepts/
I also had some extra time and created an example illustrating the behavior you mentioned. Reading up on the above articles will help explain what you're seeing a lot better!
(4,592 Views)
