NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
ishmael
Accepted Solution
How to start and stop a timed loop from an event loop
I would like to have a timed loop and an event loop running simultaneously.  Is there a simple, clean way of doing this?  (i.e. without hideous queues, etc.)  My attempt is shown below.  Unfortunately, as soon as the timed loop starts, the event loop becomes unresponsive.  Thanks for your help!
Knight of NI
altenbach
Re: How to start and stop a timed loop from an event loop
You have a data dependency and the outer loop cannot complete until everything in it has completed.
You could use a regular queue. I would recommend against hideous queues, even though I don't quite know hat that would be. :smileyvery-happy:)
In order for the event structure to be ready at all times, it needs to be in its own loop.
(Nobody likes to write examples from scratch, so please attach your code so someody here can maybe try to modify it).
Also please be more specific about the purpose of your code. What is is actually supposed to do?
LabVIEW Champion . Oh, by the way, I work for peanutsKudos .
Member
mahu
Try put the button start/stop inside the while loop and replace signal of button with NewVal, the event case will work and the control refresh your status when run.
regards
Member
ishmael
Thanks for the reply, altenbach.  I've attached my VI - sorry about that.  All I'd like my code to do is allow for a timed loop to be started or stopped with the click of a button.  In my sample code, when the timed loop is running, it should just display an increasing loop count.
Knight of NI
altenbach
[ Edited ]
You don't need the outer loop. Place the event structure inside the timed loop and manipulate the timeout between zero and infinite, depending on the desired state.
Member
ishmael
That's great, thanks!  It works perfectly, although intuitively, I would have thought that the event loop would not run until after the timed loop was already running.  In any case, this is elegant and simple.  Thank you.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
