07-13-2005 04:45 PM
07-13-2005 05:52 PM
07-13-2005 06:16 PM - edited 07-13-2005 06:16 PM
Message Edited by altenbach on 07-13-2005 04:20 PM
07-13-2005 06:23 PM
07-13-2005 06:31 PM
Thank you altenbach and tbob. I'll try your suggestions and return with Questions, if any. Thanx again.
Fataneh
07-13-2005 06:48 PM
07-13-2005 06:57 PM
07-13-2005 07:29 PM
07-13-2005 07:39 PM - edited 07-13-2005 07:39 PM
Message Edited by altenbach on 07-13-2005 05:40 PM
07-25-2005 02:30 PM
altenbach,
since your suggestion was so helpfu the last time, I want to ask you how to do the following. I'd like to add the following to my software:
I'd like to specify a Starting Sinewave Duration (say 1 sec), an Ending Sinewave Duration (say 10 sec), and an Increment for the sinewave duration. I want the software to produce my sinewave (which is in my timeout event) beginning with the Starting Sinewave Duration value, then increment the duration by the Increment value and produce the sinewave for that amount of time, and continue this process until the Ending Sinewave Duration is reached and then it stops.
I have an idea to use the Tick Count function or Elapsed Time VI. Is that the best way to do it? I always wonder if there's a simpler way to do something, and I love simple code!
I've attached my code for you to look at. Thanks a lot.
Fataneh
