Hi LINJIN,
The data aspect ratio of 3D graph in LabVIEW can be set through the "Axis" property node.
You can first specify the Axis -> Range -> Range Maximum (or Minimum) to set the limit of one axis, and then set the Axis -> Tick -> Tick Major Count to set the axis tick between limits.
