Reply
How to set Tab Control's Tabs to always hide at app startup
How to set Tab Control's Tabs to always hide at app startup ?
I want all the tabs to HIDE at the start of the application
using labview 2010 here
Message 1 of 8 (497 Views)
Reply
Re: How to set Tab Control's Tabs to always hide at app startup
You can write FALSE to the "tabs visible?" property on startup.
Message 2 of 8 (495 Views)
Where do i find the startup property?
Message 3 of 8 (490 Views)
Reply
There is no startup property. I was talking about a property of the tab control. Simply make sure it executes right at the start of the program.
Message 4 of 8 (478 Views)
Reply
you mean just leave it anywhere in the block diagram?
i tried that, it just triggers whenever ANY controls (switch, button etc) are clicked
Message 5 of 8 (461 Views)
Reply
Then show us your code. If you place it outside the main while loop, it will get triggered exactly once per run of the VI. How is your VI organized? Do you use an event structure?
Do you possibly use the "continuous run" button? (That mode is only a temporary debugging tool, NOT a valid way to run a regular program!).
Message 6 of 8 (446 Views)
Reply
thanks im going to try a while loop
currently i throw everything into an event structure and use Run Continiously
and it still runs ONCE even though i use Run Continiously
Message 7 of 8 (431 Views)
Reply
That is expected. "Run continously" basically restarts the VI whenever it completes. If you have an event structure, the VI can only complete if one of the events fires. Thus it will execute once, and then whenever an evet gets triggered.
Message 8 of 8 (425 Views)
