01-24-2015 06:39 PM
@RuiZanzibar wrote:
Hello
I forgot to tell that i have a start (7B7B) and end (7D7D) frame in the broadcast, thats why the index must be (n-1).
Hugs
That still makes no sense. If you must end wit ha 7D7D, then you should be using n-3 to eliminate that footer.
01-24-2015 06:46 PM - edited 01-24-2015 06:46 PM
Here, this will explain what I'm trying to say. Notice that the element I got removed from the Delete From Array is the same as the indexed element at index n-1. I'm trying to make your code simpler here.
01-24-2015 06:51 PM - edited 01-24-2015 06:52 PM
And here is your code simplified to just a few nodes.
