How to save OME-TIFF with Labview
Hi all,
I am developing a home-made microscope and i would like to save the image from a CCD camera in a OME-TIFF format, a TIFF-based image format that includes the OME-XML standard
(see http://www.openmicroscopy.org/site and  Bio-Format http://www.loci.wisc.edu/bio-formats/command-line-tools)
Have someone already done that ?
thanks
regards
Philippe
(6,079 Views)
Hi Mnemo15,
In fact you can save Files with .TIFF extension using NI-IMAQ drivers, you can find information in our web site:
Saving Images in LabVIEW Using NI-IMAQ Only (Without NI Vision)
http://digital.ni.com/public.nsf/allkb/B51CCE62D00112B68625735C0000DDCF?OpenDocument
Which Image File Types Are Supported by the Vision Development Module?
http://digital.ni.com/public.nsf/allkb/862567530005F09C86256759007628AF?OpenDocument
(6,027 Views)
Hi Remi.D,
the format that i am talking about it is a special tiff format developed for microMRI or PTscan images. With it you save all the informations/metadata you want (kind of experiment, number of image, z-position,....). Like that you do not need anymore a lab book where you used to write all these informations.
Give a look to this webpage: http://www.ome-xml.org/wiki/OmeTiff
regards,
(6,019 Views)
After a quick look at the specs you posted, it looks like the easiest way to support this in LabVIEW is to write your own code for the image description and save it using a standard TIFF library.  National Instruments sells the IMAQ library referenced above.  You can probably use DLLs from LibTIFF.org directly from LabVIEW.  However, I have not done this, and there are a plethora of ways DLLs can break compatibility with LabVIEW, so you may have to write some glue code.
Good Luck!
(6,003 Views)
Did you ever find anyone who has done this?
Thanks!
(5,721 Views)
Hi mnemo15,
I am also working on the same topic,
please let me know if you finally fould a solution for it.
Arash
(5,611 Views)
Wondering if anyone has solved this, could you please share how you did it or any code snippets?
(3,969 Views)
