How to run an exe as a window inside a VI
I have a VI that needs to runf an exe file i.e. the exe file should be running inside the VI and not execute as a separate window. Please suggest the best way to proceed.
Bharat
Message 1 of 39
(5,037 Views)
If the other code is in a separate compiled executable, you can't. Your best option is to grab the data from the executable using VI Server and display it in your new program.
What exactly is it that you want to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 39
(5,007 Views)
Basically, I have an exe file that is being sent from a microcontroller to the computer and I need to execute it in the LabVIEW VI in a small frame.
Message 3 of 39
(5,002 Views)
Was the other exe created in LabVIEW as well?
Mike...
LabVIEW Champion
Message 4 of 39
(4,986 Views)
No. That was created using Java.
Message 5 of 39
(4,983 Views)
In that case you are pretty much stuck. Does this java program provide any way of accessing it externally? ActveX, .net anything?
Mike...
LabVIEW Champion
Message 6 of 39
(4,980 Views)
.NET maybe but not ActiveX. Is it possible to use the .NET container to use the exe?
Message 7 of 39
(4,978 Views)
Yes that would be a possibility.
Mike...
LabVIEW Champion
Message 8 of 39
(4,973 Views)
Any suggestions as to how I can go about that? What kind of control should I select in the .NET container?
Message 9 of 39
(4,970 Views)
Well before you can do anything the java exe needs to be written such that it supports .net access.
Mike...
LabVIEW Champion
Message 10 of 39
(4,956 Views)
