06-08-2016 02:28 PM
I'm student in mechnical engeering, i have summer project about tensile test of adhesive assembly and i need to calculate automatically the surface of the crack so i choose to do it with NI vision tools,so my question is how can integrate my VI in While Loop to treshold my image and get the surface in real time
i put some example of image that i should process to get the crack surface of the adhesive joint. in purpose to calculate maximal stess before crack.
i have the 2015 labview but i could give the 2014 version
thank you in advance
06-09-2016 03:22 AM
From the code, i can see what is going to happen when running the VI. However, i have no idea what you EXPECT IT TO DO.
Could you explain what you expect vs. what is going on? What is the discrepancy?
Norbert
06-09-2016 04:35 AM - edited 06-09-2016 04:46 AM
i expect to treshold in real time the image and get the new particle measurement this is why i think to use while loop but when i lunch the VI the problem is when i treshold no thing happen the treshold image is not modified.
Please if you know how to do it i will appreciate
06-09-2016 05:50 AM
@mediaddad wrote:
[...] the treshold image is not modified.[...]
That is expected as the image terminal is not inside of the loop. So it will update only if you leave the loop, so when you stop the VI.
However, the Particle Measurement array should get updates, so ou might check this.
Norbert
06-09-2016 07:48 AM
In addition to Norbert's suggestion that if you want to see the images as the loop runs, your Display terminal needs to be inside the loop, I'd make a few more suggestions:
