06-23-2014 11:35 PM
I want to rotate the front panel component in anti-clockwise/clockwise manner, for example, if I place a square led on the front panel, how I would I able to rotate this?
Solved! Go to Solution.
06-24-2014 12:02 AM
As of I know you cannot Rotate the components (Apart from label) in the front panel. You may like this Idea to be considered.
06-24-2014 12:14 AM
06-24-2014 12:19 AM
Hey Mike,
Thanks for your reply. Actually I wanted to create a seven segment design on front panel using square LED and for this I want to rotate the component.
Ravi
06-24-2014 12:32 AM
10-09-2020 04:24 AM - edited 10-09-2020 04:25 AM
To implement 7BCD LED Or rotating square LED - follow the easy steps:
1) select Square LED on front panel
2) click on the square LED ( you'll see resize dots on the edges)
3) just use the curser to resize it - you can easily give vertical orientation to it: equivalent to rotating.
4) there us no option of rotation hence implement the above steps
