08-28-2009 01:18 PM
I want to dynamically resize an ActiveX control in LV 7.0. How do I do it?
I've tried to manipulate the container manually, by using the parent HWND, but although the ActiveX thinks it has been resized, it really hasn't. Looks like the window is being faked and then image is being clipped?
Anyway, if there is a solution, I would greatly appreciate knowing it.
Adrian
Solved! Go to Solution.
08-28-2009 01:21 PM
08-28-2009 01:26 PM
Not sure if it will help but....
Try right-clcik on the end of the container on the FP and select create property node >>> ....
If your ActiveX control acts like mine that should give you the properties of the container.
Ben
08-28-2009 02:11 PM
Thought I did that before. Thanks.
Adrian
