How to reset or disconnect all conections to an MS Access database if the database is hung up?
Hi, All:
Sometime I do not knwo why my database in local C drive is locked. If I restart the LabVIEW software, it works fine. Is there a way to disconnect all connections before you make a new connection? I remember I used this function a couple of years ago but I could not find the function in new LabVIEW database connectivity tool kit. I am using LabVIEW 8.0.1. Thanks.
Jim
(2,643 Views)
Is it DB Close Connection? You VI should contain one of these. Perhaps you are thinking of DB Tools Free Object?
David
Message Edited by David Crawford on 07-11-2006 07:38 AM
Message Edited by David Crawford on 07-11-2006 07:40 AM
(2,636 Views)
David:
Thanks for your posting. I did use the functions you mentioned. I want to know if you can disconnect all database connections if you somehow forget to disconnect. Anyway, my problem has been solved. The reason is the data source name missing after some operation.
Thanks again.
Jim
(2,621 Views)
