05-05-2009 12:10 PM
I`m using green LED vi for indicating whether the data were properly loaded. However, if I run the same labview program more times in row, then the green LED is still on because the "value that data were loaded properly" hangs there from previous session. Is it possible to reset all LED VIs after pushing STOP button (stopping labview program).
Thank you for answers.
Solved! Go to Solution.
05-05-2009 12:23 PM
05-05-2009 12:23 PM
05-05-2009 12:47 PM
Hope this helps:
05-05-2009 01:51 PM
Thanks Harold,
that is what I was asking for.
Martin
05-05-2009 02:33 PM
05-05-2009 02:41 PM
no problem happy to help
05-05-2009 02:59 PM
Harold Timmis wrote:Hope this helps:
You should really try using local variables instead of value property nodes. Sometimes none of those are needed, see attached.
I agree with Gerd that it would make much more sense to reset at program start. In the above example the LED don't reset if the VI is aborted, for example.
05-05-2009 02:59 PM
you could in the front panel initialze the LED to a false as default
05-06-2009 12:23 AM
OK,
based on your suggestions I set the default value by using property node. Don`t know how else I could this accomplish. Is that OK?
