How to replace the LabVIEW icon in the upper left corner of panels?
Hi Gang,
We're going to create an application that will go to customers.  We want to replace the LabVIEW icon in the upper left corner of panels with the company logo.  How do I replace that?
All responses will be appreciated.
Thanks in Advance,
Roger
(3,190 Views)
When you assign an icon to the build application in the build settings, Windows should use that icon for all application windows.
Rolf Kalbermatter
My Blog
(3,186 Views)
As rolfk said, edit the icon in the build specification.
GCentral
(3,176 Views)
 rolfk is right. Just be sure the icon you are going to use has multiple sizes, namely 16x16, 32x32, and 48x48. Good luck
(3,171 Views)
Accepted by topic author RogerMont
Create the Icon you want there are several ico editors on the market (I usually use one of the freebies) and save it into your project.
In the Application build spec select the Icon section, uncheck use default and select your .ico from the pop-up.
"Should be" isn't "Is" -Jay
(3,170 Views)
Hi All,
Thanks for the responses!  I knew that, but had forgotten it! (hits forehead with open hand) Smiley Wink
Thanks for reminding me!
Roger
(3,146 Views)
I really like using this web site for converting .svg files (like made from InkScape) to multiple sized .ICO files.  Find it is a lot easier than working with .ICO editors directly.
http://iconverticons.com/
(3,128 Views)
