08-31-2015 11:49 PM
@ ZentronLabsPvt.Ltd
I think creating your own control will be the only solution if you need something else then months. Then you need to make some controls transparent, so the classic controls will be a good solution for this. I clicked a little bit around, please see the attachment for a small example how this can look like. The bins were put in an array so it should be possible to pragmatically adjust the number of bins. This means the size of your control can vary.
hope this helps!
09-02-2015 11:36 PM
Thanks for the innovative idea.
09-03-2015 12:47 AM
Hi ,
I changed the format to the required one ,
but the x-axis shows same month and a default year ..
so what are further settings to get the months incremental and to the present year
