08-31-2015 12:00 AM
Hi all,
I want to put months name or other names on the x-axis of the graphs as shown in the attachment. How can replace the numeric x-axis values with string names. Can anyone help for the same.
Thanks in advance
08-31-2015 01:32 AM
I couldn't find a direct way to put stings inside. But with a graph you are able to work with time stamps. Make only the months of a time stamp visible. You can do that by right clicking your graph: properties: - go to the display format tab, chose the time x-axis
- chose under type (left side under axis pull down) absolute time
- select advanced editing mode
- type the format string %<%B>T
you will only see the months on the X axis.
Hope this helps!
Martijn
08-31-2015 01:59 AM
well: struggled a little bit using a Graph (but that's maybe just me), found a way to create an example based on XY graph. Saved to earlier version so don't mind the lay out.
08-31-2015 02:10 AM
K..
Thanks.
What should be done if I want to put some strings eg:- defect1, defect,2... etc for bar graphs for either of the axes?
08-31-2015 02:22 AM
Also I want to know whether it can be done programmatically?
08-31-2015 09:15 AM - edited 08-31-2015 09:17 AM
I responded to your original thread from a while ago. Use the %<%B>T format for the months. This can be changed programmtically by using the XScale.FormatString property in a property node.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-31-2015 10:20 AM
In the more general case, implementation of this idea would help in the future. Please vote for it. 😄 Thanks!
08-31-2015 10:26 AM
Up you go!
(It should be noted that even Excel doesn't have this functionality for line/scatter plots)
Cheers
08-31-2015 10:45 AM
This assumes that the x-axis is a timestamp and that the markers are aligned with months. Could get complicated. (note that months are not equally spaced in time because they have varying lenght, so there could be surprises)
Implementation of my idea would make things much simpler, because the months axis could just be 1..12, for example (... or 0..11 if you are thinking zero-based :D)
08-31-2015 10:57 AM - edited 08-31-2015 11:07 AM
Yup, much simpler. The way to do that right now would be to do some simple timestamp creation to match the month.
Cheers
