08-06-2015 10:18 AM
I would need to get image of a control but I'd like to replace the background color of the control with transparent color (like the commentest image editor).
I cannot use IMAQ library, so I would like to use 2D-picture palette.
I can read the image data pixel per pixer, but.. once the color to be replaced is found, how to replace it with transparent?
Thanks all
Solved! Go to Solution.
08-06-2015 10:52 AM
It sounds like you want the "Create Mask.vi". If not, you might want to provide some code that shows what kind of situation you're dealing with.
08-07-2015 01:38 AM
Thanks, I've used Create Mask and it works. I never used it before.
Thanks a lot
