11-17-2009 12:15 PM
I would like to replace a single element of an array which is converted from a cluster and then store it back in the original cluster.
The element to replace is selected by the enum Angle. The value to replace that element with is output from the sub-VI 'get raw angles.'
Will the Replace Array Subset work for replacing a single array element, leaving the rest untouched?
Here's what I've tried:
Thanks!
11-17-2009 12:25 PM
