08-26-2009 03:55 AM
Hi all,
I'm using LabVIEW 8.6.1 project window here. How can I get rid of the warning shown in the image?
The file has been moved as indicated. Refresh does not work, nor save all, I can not delete the warning under the "Files" or "Items" tab. Any ideas?
TIA
-Martin
Solved! Go to Solution.
08-26-2009 03:56 AM
Hi Martin,
did you try "clear conflicts"?
Mike
08-26-2009 04:15 AM
Hi Mike - do you mean "Resolve conflicts" as this is disabled. I can not find "Clear conflicts".
-Martin
08-26-2009 04:16 AM
Hi Martin,
yes, that's what i meant. It shouldn't be a problem, because it's only in the "Dependencies".
Mike
08-26-2009 04:22 AM
Martin.D wrote:
[...] I can not delete the warning under the "Files" or "Items" tab[...]
The reason why you cannot delete it is because the item is part of the dependencies. It shows up because some code in your application refers to this file position, but the file (DLL!) is not found there.
So in order to resolve the conflict, you have to find the Call Library Function Node which does not refer to the updated location of the DLL. "Reroute" this CLFN to the new position/name of the DLL and the entry should disappear.
Note that this entry should not effect the functionality of the application since DLLs are searched in other paths if not found in the expected one....
hope this helps,
Norbert
08-26-2009 08:12 AM
08-26-2009 08:56 PM
