12-07-2005 10:06 PM
12-08-2005 08:36 AM
With a little more effort, you could have eliminated all the front panel controls and used 100% global variables. You also didn't include any of the separate VIs (one for each global?) so the VI can't be run.
The best way to get help in a situation like this is to post an example of a file that has been written. Also, exactly how do you want the data displayed? As an XY graph or a regular graph with the correct start time? What have you tried to do on your own and what problem do you have?
12-11-2005 10:48 PM
Dear Dennis,
Now here i am attaching the file with no global variables, and from that you cn open the vi and see things what u want, and whenever i ve try it doent show the time, it only shows the data and i dont ve that example currently, and what i want is to display the time stored in the file on the X-axis and the data stord for the each channel on the Y-axis so i can see the previously stored data on the graph currently, and graph may be any one of the given in the LabVIEW.
12-12-2005 09:20 AM
