01-27-2016 08:37 PM
Please answer the following questions.
What you may "know" is that LabVIEW can't read Excel file. However, as all of us are trying to tell you, what you "know" is at least 99% wrong (on this point, anyway).
01-27-2016 09:02 PM
Dear Sir
I have used report generation tool kit as per your advise. I have to do statistical analysis of my data. But when I connect statistic.vi with report.vi it gives error. can you please guide me how to rectify this error.
01-27-2016 09:05 PM
Dear Mr Aputman
Thank you for your eply.
01-27-2016 09:07 PM
Did you hover over the broken wire and read what it says in the tip strip?
Did you try turning on the context help and reading what it says for each of those functions?
You are wiring the class wire from the toolkit into the Signals input of the Statistics Express VI. Why? They are two different things.
Why are you using the Rename Excel Worksheet function and expect to be getting signals out of it? Perhaps a function that READS the file would be more appropriate?
01-27-2016 11:05 PM
Sorry to tell you, but both by your initial statement about LabVIEW and Excel and the woeful wiring together of two random RGT functions and connecting it to a Statistics Express VI, you clearly know almost nothing about LabVIEW. You will certainly benefit greatly by taking as many of the Tutorial Sessions you can find listed on the upper right are of the Forum's Home Page.
If you want to use LabVIEW, you really have to "learn the basics", including how to connect wires together (you generally try to connect wires to terminals of the same type) and how to use the Help files associated with (almost) every LabVIEW function.
05-09-2017 10:39 AM
Thanks and praise go to James Morris, the Active Participant with the clever broom GIF!
It is refreshing to have an actual answer instead of "let me Google that for you".
11-05-2020 02:11 PM
The problem I have with the Report Generation Toolkit is that I still get a dialog box (password or Read-only), when I try to open a Password-Protected spreadsheet. I only want to open it read-only and do not want my users calling tech support (me) to ask why the program is not running because the dialog box is not visible without extra steps that are no apparent to naïve users.
