01-26-2006 12:43 AM
This should be simple. Any ideas on how to read an Excel file with csv extension using LabVIEW?
Thanks!
01-26-2006 01:05 AM
Reads a specified number of lines or rows from a numeric text file beginning at a specified character offset and converts the data to a 2D, single-precision array of numbers. You optionally can transpose the array. The VI opens the file before reading from it and closes it afterwards. You can use this VI to read a spreadsheet file saved in text format. This VI calls the Spreadsheet String to Array function to convert the data."
01-26-2006 01:07 AM
01-26-2006 02:50 AM
