06-17-2014 01:35 AM
06-17-2014 06:57 AM
Is "read BMP file" command not working, please?
06-17-2014 07:14 AM
06-17-2014 09:00 AM
http://zone.ni.com/reference/en-XX/help/371361K-01
This won't work for 32 bit depth images. Yes the read bmp file.vi i s not working for my image. When I am saving it in paint it changes to 24 bit then it works perfectly.
06-17-2014 09:04 AM
I have no clue yet. But you may consider to supply the image and the error you see. ("not working" is vague)
06-17-2014 09:17 AM
A "standard" image, by which I mean an image type most typically encountered, stores image data in RGB format with 8 bits per colour, making them 24-bit images (24bbp - bits per pixel). A 32-bit image normally includes an additional 8 bits for the alpha channel, but in BMP files this format is complex (see wiki article), and it appears the LabVIEW Read BMP function does not support it.
Do you have the IMAQ toolkit? I can't test the theory, but perhaps the IMAQ functions for reading image files are more advanced and can read your images?
06-17-2014 09:21 AM
I am attaching the error message but when I am trying to attach the picture it is saying unsupported format.
06-17-2014 09:21 AM
archive it, e.g. into ZIP or 7ZIP
06-17-2014 09:22 AM
I will try this .
06-17-2014 09:46 AM
