Good afternoon everyone! I need to make aprogram to readthe frequency of2encodersand read3temperatures. From thesefrequencies,I will be able tocalculate the speedof the wheels. When I try tocreate thistask, LabVIEWshowsthe following errors:
-You can not createtwoCountsInputsfor the same task. -When youchangethe option to"Largerangefor 2counters,"the program readsonevalueandthen locks.
I tried to createan independentclockfor the secondfrequency signalbutdid not succeedas well. Someone would havean ideahow to solvethis?
CurrentlyI use acDAQ9178,to measurethe frequencyuseto9402and9213to measuretemperature.
Please include a Snippet of your code, or attach your VIs, so that we can better assist you. It helps to see the code that you've tried that throws the error.
