10-29-2010 02:06 PM
I want to send a single 2 second pulse to the counter when a user pushed a button. I used DAX assist to generate the pulse code. How do I code the case structure so that it will run the case once (send one pulse to the counter) and then returns the button to the off position? I included the code that I currently have.
Solved! Go to Solution.
10-29-2010 11:24 PM
You just have to change the mechanical action (i.e. Latch When Released). Just like the stop button.
11-02-2010 01:02 PM
Dennis,
Thanks for the reply. I did not understand the mechanical action but using your vocabulary from your reply I was able to find an example about this action on the Boolean. The example in Labview shows the six setting and I was able to get one that worked for my situation. Thanks for the help.
