03-05-2012 03:58 PM
The short version of my question is this: I have a DLL that I must call as part of a driver package of a digitizer. The DLL runs in a loop waiting for the digitizer to be triggered. If no trigger is recieved, the DLL stays in an infinite loop. I am looking for some way to be able to hit a top button on the front panel of the VI to tell it to continue on from the DLL. There are two options I have considered, but it seems that there could be a simpler solution that I haven't found. The options I have considred are:
1) Add a time-out to the DLL itself. This is my LAST option, because there will be times when I want it to wait for an extended period of time for a trigger.
2) Use a shared variable and have the "stop" button in a different VI - then feed that variable into the DLL and have the loop end if either a trigger is found, or if the "stop" boolean is set to true. The problem with option 2 is that it requires another VI to be open and running. Again, it seems that there should be a better solution, but I am having difficulty finding one.
03-05-2012 04:04 PM
LabVIEW cannot execute any code that is dependent on the output of the DLL until the call to the DLL completes. This means that if the DLL is in a subVI and you call the subVI, then the subVI will not complete until the DLL call is completed. If it has an infinite loop (which is a bad design choice, by the way), then you have to have a parallel process running in LabVIEW. Even if it has a timeout the situation with LabVIEW waiting will be the same - LabVIEW will sit there until the DLL call has completed. Whether you choose that to be a parellel loop or another VI running in parallel is a bit dependent on the architecture and complexity of your code.
03-05-2012 04:10 PM
I agree it is a bad design choice. The other option I was considering is simply having the loop within labview. It calls the DLL to see if there is a trigger over and over, then if it is triggered reads the data. However, I have had trouble finding out if there is going to be a performance decrease by doing this.
