01-29-2013 12:31 AM - edited 01-29-2013 12:34 AM
I have an instrument that collects Current readings. I press the Run1 button, and it measures the current at different voltages on a sample. I press the second Run2 button and it also measures the current at different voltages except this time the sample is illuminated. Both Run1 and Rund 2 generate bundled clusters, which I then plot. What I want is to super-impose these two plots. The problem is I created/generatde these two bundled clusters (X and Y) separately using two case structures (latch). I try to get the clusters outside the loop, but there's the FALSE condition I have to deal with. How do I get around this?
01-29-2013 01:10 AM
Give this to build array and output of build array give to graph.
This way should work and bundle should be of time & parameter to be plotted (Make sure)
Let me know.
01-29-2013 01:23 AM
Hard to follow your code description, why not post some code?
A diagram tell more than thousand words 😉
That way you might get the fastest help.
01-30-2013 03:47 AM
Here's the VI. Technically I want the bundled array and plot graph out of the Case Structure. But I can't do that. There's a FALSE condition I hae to deal with.
01-30-2013 04:36 AM
I am attaching you one image. Look at that.
Hope this will help you
01-30-2013 09:04 AM
The shift register is your friend.
I did not have the instrument VIs so I used Diagram Disable to make a runnable VI. I substituted a sine function for the data source.
Lynn
