03-05-2015 11:55 AM
I have a 2D array and I want to plot it on a sphere like a "termal plot" . The rows and cols of the array are already the elevation e azimuth angles. How to do it?
The image below shows an exemple of sphere plot.
Frederico Araujo
Solved! Go to Solution.
03-05-2015 12:13 PM
The parameteric surface graph has an input for a color matrix as 4th dimension. I can post an example later. What's your LabVIEW version?
03-05-2015 12:35 PM
It's LabVIEW 11.0.
03-05-2015 04:52 PM - edited 03-05-2015 04:53 PM
Here is the relevant part of my old code. You would need to change the mapping of one dimension to elevation instead of angle. Shouldn't be hard.
