01-09-2013 01:17 PM - edited 01-09-2013 01:24 PM
Solved! Go to Solution.
01-09-2013 01:20 PM - edited 01-09-2013 01:49 PM
An ISO file is a CD/DVD image. You can download and install 7-zip and convert it to a regular folder (right-click...). Then open the folder and run setup to install LabVIEW.
Or you can burn it to a DVD. What is your OS?
01-09-2013 01:27 PM
I'm using Windows 7. I only have to get this LabView version to open a block diagram someone sent me, so I can print it. But I only got this file and there is no LabView-icon on my desktop.
Thank you for answering so quickly.
PS: I'm not very good with computers, so I won't understand most abbreviations.
01-09-2013 01:41 PM - edited 01-09-2013 01:41 PM
I don't know if someone could do this for me, but I'll just ask. I don't have to work with LabView (atleast not at home). I only need the block diagram to print it and to make a powerpoint, i don't need to change anything. Could I just send it to someone, and could that person send it a pdf file of the block diagram to me back, so I can print it and use it in my powerpoint?
I know this is a weird question.
01-09-2013 01:49 PM
You can attach the VI here.
01-09-2013 01:54 PM
I attached the file to this post. It would be great if you could send me the pdf version of the block diagram. It's not totally finished, but that doesn't matter, I can complete it in school.
Thank you, really, thank you.
I know that this is not the purpose of this forum, but it was the easiest solution for my problem.
01-09-2013 02:34 PM
Sorry, I need to find a computer that also has the NXT toolkit installed.
01-09-2013 03:31 PM
Can anyone do this for me?
01-09-2013 03:45 PM - edited 01-09-2013 03:47 PM
There is absolutely no need to attach the same file twice in a row. All the information is in your earlier post.
(... and nobody would understand what "do this" means without going back and read the old post!)
01-09-2013 05:19 PM
