02-22-2007 03:05 AM
02-22-2007 04:41 AM
LabVIEW itself does not have a built-in ability to format and display HTML, but if you're on Windows, you can drop an ActiveX container on the front panel and place a browser object in it (on my system, the IE object is called "Microsoft Web Browser" and it has a Navigate method which accepts a URL).
The other option is to use the Open URL in Default Browser VI (from the Help palette) which will open a new window and should work on all platforms.
