How to open Labview 8.5 VI in Labview 8.2
Hi
I am using LabVIEW 8.2.I found one ook modulation example project(http://decibel.ni.com/content/docs/DOC-1394),it was developed in Labview 8.5.I have to oepn this one in My system mean in Labview 8.2.
Please tell procedure.Is it possible or not.?
Thnaking you sir.
Message 1 of 8
(2,990 Views)
It is not possible directly. Somebody with access to version 8.5 needs to save it for version 8.2.
Message 2 of 8
(2,988 Views)
Could you attach that particular vi in your post so that somebody can save it for 8.2
[Edited: I saw the link you attached. Which specific vi you need in 8.2 version?]
Mathan
Message Edited by mathan on 05-19-2008 12:15 AM
Message 3 of 8
(2,985 Views)
Or you can install Labview 8.5 demo. Works for 30 days....
Message 4 of 8
(2,980 Views)
Hi Mathan,
Thanks for your reply.
i need OOK Modulation (FPGA).VI and OOK Modulation (HOST).VI in version 8.2
Here i am attaching this two vi please save it in version 8.2 and send to me.
Thanking you
Sreenivasulu.O
Message 5 of 8
(2,946 Views)
Hi Sreenivasulu.O,
i´m not sure if they are enough, but here they are. Smiley Happy
Mike
Message 6 of 8
(2,935 Views)
Hi Mike,
i got error like this.
Here i am attaching two error image what i got.please check nad correct me.
One more "OOK_Pack Bits for transmission.VI"  and "OOK_Configuration IF RIO for Transmission.VI" was not found.
Thanking you sir
Sreenivasulu.O
Message 7 of 8
(2,850 Views)
Hi Sreenivasulu,
These errors are probably because you did not convert the project to 8.2 in addition to the VI's. I don't think you need to have the original project, just create a new one yourself, add the target you need (CompactRIO or R-series board), and add the VI's to the project. Lastly, you need to delete and replace the I/O nodes on the FPGA VI and the FPGA VI reference on the host VI.
Eli S.
Message 8 of 8
(2,819 Views)
