06-17-2014 02:49 PM
I am acquiring two analog signals( voltage and current) using NI myDAQ device. I am using DAQ assistant to configure the two analog input channels(voltage and current) I am able to see the current response with respect to applied voltage using a X-Y graph. However, the graph is too wide. is there any way I can get a nice thin graph. I think I probably have to average the data points that I am collecting but I dont know how to do it. Any kind of help is greatly appreciated.
I have attached the screen shot of the VI.
Mahesh
06-17-2014 06:32 PM
Look at the linewidth and interpolation setting in the graph properties. Use linear interpolation.
If this is related to your other questions, note that you use a weird interpolation and never clear the xy graph, meaning that you accumulate an infinite amount of traces eventually, until you run out of memory. Both problems can contribute to the apparent width.
