12-11-2015 08:33 AM
I'm creating a library of subVIs for a working group, and the terminals need to be arranged more rationally than they come out when I simply create the subVI. Is there a way to move the terminals around?
12-11-2015 09:58 AM
hold ctrl while clicking on them allows you to swap two terminals
12-11-2015 10:56 AM
Click the first of two terminals that you wish to swap. Hold control while clicking the second terminal you wish you swap. You can swap with blank terminals as well.
12-11-2015 12:28 PM
When I finally found where to do that (left icon, upper right-hand corner of Front Panel window), it worked beautifully. Thanks much. Brent
12-11-2015 04:40 PM
Of course you need to watch out if you also leave the subVI in the code where you created it. Swaping connectors on the connector pane will NOT swap the connected wires in the calling VI. You need to be very careful, especially if several terminals are of the same datatype.
12-11-2015 11:17 PM - edited 12-11-2015 11:18 PM
Hope for broken arrows in every VI that uses this subVI, otherwise you may not catch all the mistakes as LabVIEW tries to guess where the old wires are supposed to go. What I do, if at all possible, is to actually change the pattern to something similar, then make the change. Then all the VIs that use this subVI have broken arrows because they will all complain about needing to be re-linked. Re-link them and check them as you go. If needed, you can always re-choose the original pattern and re-re-link them.
12-12-2015 09:48 AM
Remember that this only applies to callers which are actually loaded when you make this change. If the VI you're changing might be called by other VIs, which are not loaded, you should be aware of that and take appropriate steps (like loading those VIs before modification, or not doing the modification or having unit tests to see that they still work).
12-12-2015 01:23 PM
@tst wrote:
@billko wrote:
What I do, if at all possible, is to actually change the pattern to something similar, then make the change. Then all the VIs that use this subVI have broken arrows because they will all complain about needing to be re-linked. Re-link them and check them as you go. If needed, you can always re-choose the original pattern and re-re-link them.Remember that this only applies to callers which are actually loaded when you make this change. If the VI you're changing might be called by other VIs, which are not loaded, you should be aware of that and take appropriate steps (like loading those VIs before modification, or not doing the modification or having unit tests to see that they still work).
True. I forgot that step because I do that so automatically. Thanks for fixing my suggestion. 🙂
