How to measure digital output of linear actuator on USB 6009?
I am a new Labview user and need help with measuring a digital input signal.
I have a Bimba Original Line Electric actuator with an integrated DC motor with encoder, drive, and controller. The drive has a programmable digital output which I have set as a tachometer output that emits 100 square wave pulses per revolution of the motor. I have set the motor to make a total of 56 rev over 22 sec. I want to measure the real-time motor rpm on labview and synchronize it with a few other analog input signals. I wired the actuator to the USB-6009 as shown below.
I opened the USB-6009 Digital I/O test panel and set all the port 0 lines as inputs. However, when I click start and run the actuator, the p0.0 led doesn't blink, as shown below.
Shouldn't the led blink in response to the motor revolutions?
I essentially want to collect the pulse signals from the drive and convert them to rpm on labview.
(3,177 Views)
If you are looking to measure the speed, you should be using the Counter.  If you want to look at the pulses with your analog data, I would wire up that digital output to an analog input and add it to your analog input task.
GCentral
(3,172 Views)
I rewired the positive drive output from P0.0 to PFI 0 as shown below.
Then I ran the counter I/O test panel while running the actuator, but the counter remains at zero. The screenshot is below.
Did I wire it correctly?
(3,154 Views)
Accepted by topic author ahsan2
It would help if you did not tie the signal HIGH.  Remove the +5V from the circuit.
GCentral
(3,146 Views)
