11-18-2014 04:30 PM
Just updated with controls that give a square array of selectors:
Still a few lines that I can't remove.
02-18-2017 02:48 AM - edited 02-18-2017 02:49 AM
I know this message is so old, but GregS - how did you get the Boolean 1D array to look so perfect? I am trying to adopt your method to construct the table with paths. However, I am running into issue where there is extra free empty space around the path control.
02-18-2017 03:13 PM
Couple of things help - turning off any autosizing of the cluster, and choosing the indicators carefully. Here's an example which uses a Classic Path indicator - see if it does what you want.
02-18-2017 05:45 PM
Thanks GergS. Good point on "choosing the indicators carefully". I was using the silver path indicator hence my issue. I see that you used the system path indicator.
02-19-2017 12:37 PM
Yes, the Silver controls do not have a frameless path control like they do have a frameless string. I think it's actually a Classic rather than a System path that I used (I don't think system controls are so easy to make parts transparent).
