06-09-2014 07:08 AM
I am new to labview and USRP and I am trying to explore my new USRP2920. I have been able to work out an example of fm receiver but I now want to make a radio station of my own..Can any1 help plzzz
06-09-2014 08:59 PM
Hi chahatb,
There is a few example of FM transmitter on NI website. You may want to have a look on those. Some of the example can be found as below,
https://decibel.ni.com/content/docs/DOC-24206
https://decibel.ni.com/content/docs/DOC-25893
There also examples on transmitting signal using USRP that are shipped with USRP which can be found as below
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\instr\niUSRP\
TuiTui
06-10-2014 03:14 AM
Hi TuiTui,
Thanks for the help but earlier also I went through this example and the problem I found was that it is not transmitting any audible sound. Also do you have any idea how to convert a song into transmittable form???
06-11-2014 02:09 AM
Hi chahatb,
That's weird I was able to run the VI from this link and hear the sound from a sound file, https://decibel.ni.com/content/docs/DOC-25893
The question would be how you receive the sound waveform? What is the song file you use to transmit? I would suggest you to try .wav file as i use this file format and it works.
Also make sure that the signal is not interfered by radio frequency from radio station.
TuiTui
06-11-2014 05:03 AM
Thanks!! It works.
Can you advice some texts I need to go through to understand that .vi and to be able to make one of my own?
06-11-2014 06:18 AM
Hello TuiTui,
Is it possible to transfer live recording from microphone with modifications to above vi??or if u can sugges some new vi..I am trying to make a mini radio channel of my own
06-11-2014 08:43 PM
Hi chahatb,
Yes you can do it with your microphone. You can search through an example called "continuous sound input.vi" from example finder (Help->Find examples...).
you then can combine the two VIs together.
For the text explaination of the previous VI, i would say that it read a waveform from a .wav file, resample the waveform, and FM modulate the signal.
I will leave theory for you as i believe you can search those information on the internet.
TuiTui
06-16-2014 04:25 AM
Hi TuiTui,
I tried combining the two but it wasn't working. Please help.
06-16-2014 04:59 AM
Hi chahatb,
You might need to show me how you combine the two. If possible, please capture a screenshot or post a VI.
TuiTui
