Hi, I'm new to LabVIEW and I want to introduce a dead time in the analog signals that I have attached in this post. The time difference varies, so I could not introduce a time delay in the signal
for instance, the attached waveform, i want the first signal to be seperated from the second signal. so i got 2 different signal at the end of the day for analysis. during the no signal time no signal is not recorded.
It is possible to introduce a delay in an analog output. This is best done by specifying a trigger and then beginning the output when that trigger occurs.Below is a link to an example program developed for LabVIEW that waits a specified number of seconds and then triggers analog output to begin.I think this is what you mean as dead time.Take a look at this example and try to build from it for your code. If you have any further questions on this issue, let me know.
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Thanks as kudos only:)
