08-02-2013 07:08 AM
hi all
I need to select the text files multiple times and read files one by one
some how i managed to select the one text file and scan the data in the text file
i need to do this for mutiple files at the same time
please help me
Solved! Go to Solution.
08-02-2013 07:17 AM
If you know how to process one file, take that VI, put it inside a loop and pass in an array of file paths.
Mike...
08-02-2013 07:35 AM
Post your work so far. We will take it from that point...
Mathan
08-02-2013 07:43 AM
To be more exact, use a FOR loop with autoindexing turned on for you array of files.
08-02-2013 07:55 AM
gowthamggk wrote:I need to select the text files multiple times and read files one by one
Great!! You managed to read one file.. Now the same code you might need to repeat in a For loop... Well everyone is suggesting the same and that's the only way (for repetitive work, it needs to be done in a loop).
You also need the array of file paths, and very importantly you need to learn the concept of Auto Indexing.
08-02-2013 09:29 AM
i want to handle mutiple file for this VI
.. this is program for pinging the systems
08-02-2013 09:42 AM
Can u attach your VI? That image is to small to see anything....
08-02-2013 09:43 AM
Post your vi instead of an image.
Mathan
08-03-2013 11:45 AM
i sucessfully reading one text file through this VI
but as like this .. i need for multiple files
also shld read the text line by line
please help me frnds...
08-03-2013 12:58 PM
Why are you not using For loop???
You can right click the 'Read from Text File' function and select 'Read Lines'. Refer to below code snippet.
